Driving home from work today, I did my usual 'merge' into traffic using the short entrance ramp. I eased out and then rolled into the throttle hard. For some reason, the car did not shift into second gear, hanging up at the top of first. I lifted immediately, concerned, and resumed normal driving. Shortly thereafter, I leaned on the throttle again to see if I indeed had a problem. This time I was rolling, and the car downshifted to second gear pulled smoothly, and upshifted to third. Boost did not exceed 15 lbs, as I expected. When I lifted, the car immediately stalled. I pulled over onto the shoulder and re-started the car. It fired right up and then promptly stalled. I started the car again with the same result. I started the car a third time, and kept the car running with the throttle. O2's were in the 700's and 800's at idle, but eventually returned to normal. Nothing has changed in the tune-up in the recent past.
I got back on the road and was shocked to see the oil pressure gauge (mechanical) reading about 15 psi lower than normal. At cruise, it is usually about 55 lbs, and 35 lbs or so at idle. Cruise oil pressure is now about 40 lbs, and drops to 15 - 20 at idle.
As soon as I got home, we changed the oil and filter (which had less than 200 miles on them). The oil looked fine, with no metal on the magnetic drain plug. Upon re-start, the oil pressure still reads lower than it did before this adventure.
There appears to be a faint tapping in the right front of the motor. It's difficult to tell, but it seems to be more in the valve cover than the lower engine. Could I have overspun the engine and bent a pushrod, or collapsed a lifter? The sound is very faint at idle, but slightly more noticeable when I move the throttle. Would either of these failures cause the lower oil pressure readings?
The motor is well-built, with good parts, and about 9K miles. I hope that the problem is not in the lower end. Any thoughts?
