Ok, yes its a hotair car but that shouldn't matter. anyways so i went out and worked on my car this weekend. i was having poping issues so i converted my 25 year old coil pack and module to an 87 setup. i also added a ccci hotwire as well. i changed out my old fuel pump with a new one and my old hotwire to a new one as well. anyways i took the car out at night to check and make sure the poping was fixed. made on pass and it was fine. made another with more boost it was fine. thats the basics,well at the topend of that pull the VOLT light came on, on the dash. Then the headlights flickered off, i clicked the high beams on, they turned on, then flickered off. i do have the caspers headlight hotwire harness which wires straight to the back of the alternator. i pulled off the side of the road and left it running, (volts light still on) looked under the hood at the wiring and didnt see anything crazy. kinda had a weird smell but couldn't figure it out. so i drove it home with the flashers behind another buick. parking lights worked,flashers and brake lights worked as well. got home shut it off and saw the optima red top battery was leaking out the vent. pulled the battery out as fast as i could. i changed the battery out and then tryed to figure out what happened to the headlights. well after trying to figure it out all 4 headlights where burned out? voltage spike? so i put new headlights in it and they worked, started the car now the smell came back. alternator was making a really bad noise and started making a burning smell checked the voltage at the alternator and it was putting of 13.* volts. so i shut it off and removed the belt. car ran fine no smell or noise so its the alternator. So for the question
The alternator is a turbobuicks.com 140amp. TurboBuicks.com Store: TurboBuicks.com 140AMP Alternator for '84-'85 Grand National, Grand National Hardware, TBS900 its about 2 years old but maybe has 2,000 miles on it
The battery is a optima red top thats about 7 years old. always on a battery tender and has never been a problem for me. (lets not make this a optima bashing thread)
So what happend? did the alternator have a voltage spike then die, thus causing the battery to over charge and bust and start leaking?
or did the battery take a crap and then the alternator try to put a load on it and then it failed?
Im guessing the headlights took a crap since there straight hotwired to the alternator. So with that being said im guessing the alternator gave out had a voltage spike blew the lights out then overcharged the battey causing to to pop?
please help. as of right now the car has no alternator in it (plan on sending my turbobuicks.com one back for a rebuild maybe) nor does it have a battery. so what do you guys think? i think the alternator took a **** killing my $100 headlights and my $200 battery. what do you think?
sorry for the long post. if there is any electrical gurus pleas pm me your # or call me if that is better for you.
