S Steve Well-Known Member Joined Jun 1, 2001 Apr 27, 2002 #1 The green connector behind the alt. does not work on my T-type, where else can I get the tach signal? Thanks Steve
R Red Regal T Senior Member Joined May 24, 2001 Apr 27, 2002 #2 I think one of the wires off the ignition module. Problem is, I don't know which one.
A azgn New Member Joined May 24, 2001 Apr 27, 2002 #3 are you sure it is the wire and not your tach? If it is a new VDO, it probably needs to be modified...
S Steve Well-Known Member Joined Jun 1, 2001 Apr 27, 2002 #4 I am pretty sure that its not the shift lite because I tried the shift lite and a different tach and neither worked. Also none of the pins on the ign. module have continuity with the green plus. Thanks Steve
T Turbo__Tim One heck of a Tim! Joined May 25, 2001 Apr 27, 2002 #5 White wire at the ECM that connects to B-4 should work.
T Turbo__Tim One heck of a Tim! Joined May 25, 2001 Apr 27, 2002 #7 Not nearly as smart as the dude that showed us how to fix leaky T-Tops for 5 bucks!
