Shamusvelez
- Mar 24, 2012
Ok..... Overhauled my 85' gn. Brand new just about everything. Rebuilt motor with a reputable builder everything brand new, as well as most of the bolt ons ( altenator, starter, water pump, intake manifold etc.)
Having a problem with the oil-choke light, Oil pressure problem. Housing is brand new as was replaced with the engine rebuild. Motor mech fiddled and adjusted a couple of things as per his advisors ( springs, shims, etc.) things in and around the oil pump housing. Things i know nothing about. Im new to this so i just would like to know.... What other things with this car could it be thats causing the oil-choke light to come on? I know these motors are problematic when it comes to the oil flowing, just need some input from folks that have maybe had similar problems and what remedies were used to fix them. A broader process of elimination. Bare in mind im temporarily canceling out the possibility that its the cam bearing, or something that was f-ed up in the rebuild process (tolerances etc.) because this is an experienced motor builder. What else causes oil pressure problems??? Please help me!!!
