Need coil boots for TR6
Reedogg
I have a set of 10.4 mm Taylor Thundervolt wires that I'm using with the TR6 ignition. Since these wires were new I swapped the coil boots when I did the TR6 installation. The terminals are different from the stock coil. The coil boots I'm using are the 45° LS angled boots which aren't ideal because the wires touch the hood pad. Does anyone know where I can pick up some 90° coil boots? Part numbers would be helpful.
Thanks!
Taylor 46067 appears to be the right boot but they don't fit a 10.4 mm wire despite the application info. Looking for something a bit lower profile.
I believe Jegs sells the bare wire and boots so u can assemble your own custom wires.
