turboculosis
Pleasant peasant
- Jan 19, 2002
I was previously running a A1000 pump from Aeromotive. I now have the Eliminator pump from Aeromotive. My problem is that my sumped tank has 3/8 ports. Which I ran a single -10 line from to prefilter/ pump on my old setup. Now the new pump has a -12 inlet and was thinking........
Option 1: Use both sump ports w/ (-10's or -8's) into a yblock and out a single -12 to prefilter/ pump.
Option 2: Jegs sells the Eliminator pump w/ the "easy install kit" containing a -10/-12 reducer to be installed on the inlet of the pump. I'm not sure if Aeromotive suggests to do this though. But this is the easiest.
Option 3: Buy new tank then sump it w/ 1/2 ports.
