Thanks for the quick responses. I bought the radiator and finished it up probably 4 hours after making the first post. I wasted about 1/2 an hour after putting radiator in my trunk, closing the trunk, and then realizing my keys were in there. I had locked myself out. I went back into autozone and bought a universal dipstick, and a set of needlenose pliers. I went to my car, and bent the dipstick into a jimmying tool and broke into the car. People were staring at me like I was a theif.
Autozone had the radiator in stock, (Autozone#- 433918) and I got lucky for once because the holes that sometimes arent plugged, were plugged, which saved me alot of trouble. As far as the oil cooler lines go, I had to get it done before it got dark, so I was out there figuring out what to do before I read the last post about removing the whole "hub". I ended up cutting the metal end pieces off the oil tubes, flaring the ends, and using my own hose to loop around. So I have no oil cooler. Just the factory end fittings, connected to a rubber hose that loops around. I wanted to do it this way so I could hook up an oil cooler soon.
The radiator is seriously a perfect drop in. Ive heard about the rubber mount pads having to be moved or something...not true in my case. It drops right in. I didnt use the tranny cooler hookups on the radiator cause of my magical exploding tranny line debacle last week that ended in me getting an external cooler. By the way, I did pull the new tranny cooler hoses off the steel tranny fluid lines, flared the ends, and then put the rubber hose back on with double fuel injection clamps like people suggested. Dont want those blowing off.
This is the best mod Ive done yet. There is a 3 mile, 6 degree grade that I climb up on the way to work every day. My temps have always risen from 175 to 205-215 by the time I reach the top. Its even hit 225 before in the dead of summer. Today, I went from 162 up to 168 by the time I hit the top, and within 15 seconds it had dropped back to 162 (this is where it runs all the time). A ****ping 6 degrees. This radiator cools really really well, and I'd recommend it to anyone. Autozone has a lowest price guarantee thing going on right now, so if anyone wants to get one of these radiators, now is the time. The price was $109! And the complaints about the radiator being out of square...not so with mine. Everything is just fine. Even if it was a little crooked, as long as the top and the bottom are co-linear, everything should be ok. It also helps if your cooling system is clean (water jackets in the block and everywhere). Ive dumped my coolant 4 or 5 times in the past year. It used to be really crusty but is now fairly clean. If you stick a new radiator on an engine with filthy cooling jackets, the new core will clog fast and kinda makes the whole thing a waste of time. Clean your coolant system first!
