I already have this in another thread, about replacing the rear main. Wanted to start another one in regards to the current issue.
Basically every time after I had the car running and I shut the car off it would start to leak oil from somewhere in the top passanger side corner of the intake or head and run down the tranny and block and leak on to starter, crossover pipe, etc. causing it to smoke upon the next start up. Again it is only when you shut the car off and it leaks oil at a decent rate, not just a drop an hour. Then after it leaks so much oil it will stop .
I currently have the entire intake, etc off the car, and gaskets don't look bad. What the hell could it be?
