My Hot Air at the track again .... new best 11.87 sec
I have temp sensor in the back of intake. Currently it is not in the direct air flow ( future correction ) . Post turbo I have been up to 200 degrees I added a 5 gph Alky nozzle pre turbo just behind air filter at the core support. That dropped intake temps to 160's . Larger turbo in the works. Making larger throttle body in the next few weeks . Will order turbo when that is complete
Data ..... Top of third gear
Rpm 5450
Boost 23 psi
CTS. 175
IAT. 195
SA 21 dgs
Inj DC 72
Nb o2. 893
WB AFR 10.5. E85 scale 7.0
Alky control set on 3
Outside temps in the mid 70's
Rpm 5450
Boost 23 psi
CTS. 175
IAT. 195
SA 21 dgs
Inj DC 72
Nb o2. 893
thanks for the info I run a lot more rpm (6000 shifts ) and 28 lbs boost. Never could get those temps blow 200 degrees. John
Working my way up to those levels. A little at a time.
Hardware change with new turbo. Then see where tuning takes it .
Could never keep my under 255 once I started making serious power. I would love to have done a nozzle pre and post turbo but distribution might start getting hairy
