Buick Parts for Sale
Buyer Pays Up Front Price and All Shipping Costs – Details/pics available
Reply here or e-mail bbucca@gte.net, will check daily - No PM
Combine items to keep shipping costs low
1 complete 1987 Turbo Buick Engine with 96K miles and stock rebuilt turbo and 2 good used cams 1 with lifters $1,500.00
1 new set adjustable pushrods $15.00
1 new set ARP head bolts $15.00
1 Flexplate $12.00
1 Power Master brake cylinder rebuild kit 18038510 $30.00
1 New AC pressure cycle switch 25527510 $20.00
1 New Power Master pressure switch, gray 18018141 $60.00
1 30Lb R12 cylinder with ~9lbs used - Licensed buyers only - Shipping? $350.00
1 14Oz R12 Quick charge cylinder - Licensed buyers only - Shipping? $20.00
1 12Oz R12 Quick charge cylinder - Licensed buyers only - Shipping? $18.00
2 4Oz R12 Oil Quick charge cylinder - Licensed buyers only - Shipping? $10.00
1 Power Master Ball $25.00
1 Used Power Master motor/pump $25.00
1 Power Master mount and petal to convert from vacuum back to Power Master $10.00
1 87 GM MAF $75.00
1 84 GM MAF $50.00
1 new set HD valve springs $12.00
1 complete in tank fuel pump assembly with a stock pump w/60K, and 2 new socks $15.00
1 New unused belt idler/tensioner assembly $45.00
1 good used coil assembly $25.00
1 used cam position sensor with new shims $15.00
1 new lower ball joint $5.00
1 new set factory body mounts (8) $25.00
1 New cruise control cable 25525358 $20.00
1 Cruise control module 25074740 used $25.00
1 New AC Delco O2 sensor 25162693 $20.00
2 New upper control arm bushings $10.00
3 New CV893C PCV valves $7.00
1 New 86 GN center cap $20.00
1 Used 86 GN center cap $10.00
1 New thermostat housing with 3 O-rings $7.00
2 New 180 degree thermostats $7.00
1 New fuel pump relay 10038490 $20.00
1 New oil pressure switch, 3 prong $20.00
1 Box 10 turbo bleed solenoid filters $5.00
1 New turbo bleed solenoid $20.00
1 New EGR solenoid $25.00
2 ATR PCV check valves $12.00
2 Temp senders new 25036979 $7.00
1 Set of 6 fuel injector seal kits $5.00
1 new ~ 6 foot length PS hose shield $4.00
1 Set heads $25.00
1 Torque converter stock GM remanufactured , used $25.00
2 Trans governor body gaskets 8634477 $2.00
1 New transmission speedometer adapter with a green gear 25524924 $10.00
1 New trans to drive shaft yoke $25.00
1 New valve body spacer plate and 2 VB and 1 C gaskets 8657309 $15.00
2 Steel shim head gaskets 25524599 $25.00
4 Felpro 9441PT head gaskets $45.00
2 GM stock head gaskets 25528486 $35.00
1 Intake gasket set $15.00
1 Trans rebuild kit (ATR) with hardened stator and sunshell $170.00
1 Drivers side exhaust manifold with loose shield $15.00
2 86 GN wheels $20.00
1 Space saver spare $5.00
1 Pair front small bumperette plastics used $7.00
1 Pair rear small bumperettes metal and rubber strip used/scratched underneath $7.00
1 84 T-Type turbine wheel with tire $15.00
1 Box Misc gaskets $10.00
1 oil pan, cork
8 oil pump cover
2 sets neoprene crank seals
1 bag o-rings and washer seals
1 rear main cap seal
1 diff cover
2 upper intake
2 different downpipe seals
2 different torque converter seals
2 turbo inlet
2 fuel pump block
5 vacuum block
1 set valve O-rings and others
1 25530999 seal
Misc others
1 Flexplate $12.00
1 87 GM MAF $75.00
1 84 GM MAF $50.00
1 Set heads $25.00
1 oil pan, cork
8 oil pump cover
1 diff cover
2 upper intake
2 turbo inlet
2 fuel pump block
5 vacuum block
1 25530999 seal
Misc others
