I'm trying to add a small (50hp) shot to my blown 396 combo... the problem seems to be that in the nitrous fuel map, there is a minimum fuel value that i can add (i can't set it down to 0, about 22lb/hr or so is the lowest it will go), and for a 50hp shot its way too much fuel... when i hit the nitrous the AFR goes to 10.4:1 and i lose most of the gains of the nitrous by being too rich (50hp shot adds 10rwhp)... am i missing something here or was the system not designed to do anything below 75hp or so?
thanks,
Jeff
ps. i don't want to use the system to do wet nitrous because the fuel pressure is climbing as the boost increases so this would be very hard to tune unless i had a second fpr...
thanks,
Jeff
