sasmith350
- Dec 1, 2005
cleaning out the garage so i can finish my projects and move on to the next one...
pics at sasmith350 - Photobucket - Video and Image Hosting
random parts..
stock t-56 shifter, pretty rusty on the handle...$20
2 sets 5.3 truck manifolds...$20 a set(i'll include the turndowns with the 1st set sold)
truck motor mounts...$5
5.3 auto flexplate...$20
2 rear hub bearings off a cadillac, would work great to make a small trailer...$15
sway links...tie rod end style...not sure what i had them for...$5
solid pinion spacer kit for ford 9" diff (sells for $30 thru summit) $20
ford 9" center section with open diff (28 spline) i'll toss in a second yoke for free along with a random u-joint i found....$75
hub w/o bearing for a nissan 300z....cost over $100 at the dealer...$15
vapor vent solenoid and line from a 2000 model 5.3...$15
turbo from an Isuzu NPR...bad diaphram, couple broken bolts in the exhaust flange...make an offer...
battery cable, think it's around 8-9 ft...$5
aluminum elbow 3.5 diameter with a silicone connecter....$5
g-body/regal stuff
rear fender extensions, white, no damage....$10 for the pair
lower steering shaft, ragjoint in excellent shape, rubber boot pretty rough...$10
rear lower control arms, double drilled for the sway bar, need new bushings...$20 for the pair
factory style "driveshaft loop"....$5
clear turn signal lenses, 2 right, 1 left....$15
pass rear taillight lens with blackout trim(small chip out of the corner/hail damage to lens)...$20
near complete set of brown interior for a t-top car, missing driver rear panel and t-top sections....$50
blue passenger side b-pillar trim...$5
a-pillar trim for a t-top car, painted grey with vinyl dye...$10
bunch of chrome/blackout trim from different regals...4 black wheelwell trim, 3 chrome, 2 chrome cowl trim, 1 black....all for $50
chrome rear windows....$10 for the pair
random lot of stuff too good to throw away(ecm/dash plaque/used hood shocks...etc) make an offer
front sway bar brackets, rear control arm "anti-crush" brackets for rear sway bar, x-member frame bushing...make an offer
electronics
audiovox car alarm...needs remote battery's, has extra led light...$30
roadmaster cb with magnetic mount antenna and a pa speaker...still works, even though it looks rough...$10
pioneer 3.5 speakers...$5
stock gm 3.5 speakers...make an offer
pyramid 4x10 speakers....$5
jensen 250 watt amp...$15
mtx crossover....$15
pyramid powered eq....$10
tools
2 cordless drills 14.4 volt, won't hold a charge overnight...$10
air nailer/stapler...new, came in a tool kit...$10
craftsman 1/4 air hose...probably a 25-30 foot....$10
random stuff
simmons binoculars...$15
ps2 games and remote(max payne 2, corvette racing, ihra drag 2, clocktower 3,)...make an offer
ps1 games(diablo, gt2, bushido blade 2) and 2 memory cards...make an offer
dartboard and darts(2 boxes are new) with scoreboard ....make offer
prices are kind of flexible, might add to the list later....some free stuff not listed to people who show up and buy stuff...
shipping is extra, pm me with an address for a shipping quote...
random parts..
g-body/regal stuff
electronics
tools
random stuff
