Charlie speaks the truth, I've seen more costly damage from a failed "pilot" bearing than any bushing ever thought of.
Main causes for either can be traced to alignment or excess heat issues, at least the bushing in worst case's "gives up" and saves the input gear nose(tit) from getting scored/chewed up needing replacement, and people think 200-4R parts are expensive....wait until you need some countershafts for a stick shift.
Good luck,
Kevin.
