M&A headbolt PN for 109 Block
CraigT
I need the PN for ARP bolts to use M&A heads on a stock block. I ordered the bolts listed for the M&A's but they are for the stage block. PN I ordered is 123-3602.
did you ever find out what the part # was for the head bolts? i also need to know..thanks,joel
I put my old M & A heads onto a 109 block this past winter. The heads came off my stage block.
I was able to reuse some of the studs but to find the length of the few I still needed I put a little 90 degree bend onto the end of a wire and stuck it down through the head and deck until it hooked under the threads in the block. Then I measured the wire and added the thickness of a washer and nut and ordered that length directly from ARP.
Dunno if this is the proper way of doing it but it seemed to work.
Chris
Sorry, I don't have them. Probably just wrote them down on a scrap of paper, ordered the studs, then threw the paper away.
And I ain't removing the studs from the engine to measure them for you. :D
I have a set of the stag II bolts I orded them by mistake but need the mesuremnts for the bolts to be used on a 109 block with the M&A's
Measurements were taken from under the bolt head without the washer.
Long- 4 3/16
Med- 3 1/4
Short- 3 1/16
Hope that helps.
