Hedge
- Sep 2, 2005
Recently I had my 87 GN in the shop for the following. Replacing crank sensor, front and rear main seals, oil pan gasket, timing chain cover gasket and timing chain. I had some serious oil leaks.
Before I put the car in the boost PSI was 17 - 18.
After I got the car back the boost goes to about 13 PSI max.
It also seems sluggish to build boost from a stop. If I am doing 55 plus the boost builds almost like normal.
Any suggestions where I could look for the cause?
Everything is stock.
