I installed the oil pressure guage and have some numbers. The pressure seems to be good. 75psi on a cold start and about 13psi when warmed up. put some new oil in it as well and it clouded up pretty quickly and turned grayish. There is no debris in my oil. My father saw some auto tv show that mentioned blow-by can make your oil cloudy like this. During my test with oil pressure I noticed that there was more smoke than usuall on start up. It didn't go away once the car warmed up. The smoke looked blue so I'm certain I'm burning oil now... I drove it around a little bit and the smoke seemed to reduce it self.
QUOTE]
ive noticed with my cars oil that one oil change hardly effects its color. if u ever have ur oil pan down and take a look, there is a raised bung in the pan about 1/4"-3/8" tall, cant remember exactly, for the drain plug, so when u drain the oil there is still that much oil across the whole surface of the oil pan and if it has material in it that is more dense than oil it will stay in the pan! hope that makes sense
def. do the comp. test and post results!
