Lots of parts for sale
crazygn
10's here i come
te63 turbo,no waste gate or elbow, 20 miles on rebuild- 700.00
scan master - 185
stock maf - 50
maf pipe and k&n filter- 25
race gate- 200
3"down pipe w/ race gate spot to hook to/ ebow 1ft long 60.00
stock headers and cross over, no leaks, cross over has dent 110
new high 60lb injectors 20miles on them- 325
turbo tweaked 110 chip and 93 chip 35.00 ea
old v8 rad , has pin hole but wont leak offer
ram chargers duel fans, end brackets are cut off , 3 hours of run time. 55.00
BOP case th 350 trans, just rebuilt, hard hub and ati manule
valve body 20 miles on trans, pick up only
pats 10" stall 3500-3800- 20 miles-200.00
pro stick shifter 200r4 or i have the 3 speed plate for it 80.00
kerkly alum seats w covers- 150 pick up only
gauges , water temp, tec with shift light
5 point rci seat belt new, 35.00
areo motive fuel pump and fuel inj filter
2 86-87 ecms 30 ea
motor intake to pan no brakets, new water pump, needs rings. will not ship, heads [ home ported , lt1 spring, and cut for lock wire gaskets] no injectors or headers, offer will not ship
2.5 sil 90* like new 15.00
nice up pipe- 20.00
dynomax bulitt muffler used 20 miles 15.00
rx7 will be sold also body,cowl hood, 8.8 rear 3.73 gears, ladders bar sup, drive shaft, roll cage
might have more
Interested in the fuel pump. What model is it and how much HP will it support? Also interested in the 5 pt. seat belts. Any chance you could email pics to sachsdca@msn.com
Thanks,
Derek:cool:
Interested in the injectors, and the chips if they match.
Be a couple of weeks b4 I know for sure, if they are still there.
Maf Pipe
I would like the MAF pipe and K&N filter. Please email me at quik87gn@aol.com to give me payment instructions. Shipping would be to 10305. Thank you
Chris
Maf too
You know what...illl take the maf sensor as long as its known good, in addition to the maf pipe and K&N. Could you do 75 shipped for the package to 10305. You can email payment instructions to quik87gn@aol.com. Thanks,
Chris
emails sent,
i cant do 150 for the stall i just paid 350 for it, its for a th350 also , not sure if you know that or not.
something just came up, need to leave town
i will be putting a hold on all parts till next week, sorry.
ok the conveter is sold for the 200.00 please call me a.s.a.p at home i will pick it up this weekend please call me thanks (856)273 8508..
sorry will this only fit a 350 if so cant use sorry again . but how much do you want for the motor???
yes i think it will only fit a th350 or th400, sorry man.
iam not sure what the engine is worth, it will come with , no front brakets or injectors, make an offer, its in the car and runs but smokes.
my brother will be pulling all the parts this week so they are ready to go.
thanks every one
and the th350 has a deep alum pan on it and an fitting where the lines are
will also let the whole car go as is with all parts for 4200.00 with my conv pro rims and race tires like new.
VERYQUICK6
the stall will bolt to the stock 3.8 buick motor fly wheel if thats what you are talking about , hope it helps, you would be getting a good deal here
sent mail
i also have
2 coil packs with modules- offer
1 crank fan -offer
i adj fuel pressure reg - 60.00
this is the Areomotive fuel pump that i have also, this is what summit says about it
Feed your beast with these new Aeromotive 800 HP EFI fuel pumps. Beautiful, compact, durable, and reliable, these fuel pumps will fuel the fire whether it's naturally aspirated, nitrous enhanced, blown or turbocharged. These pumps are for fuel injected applications with base pressure settings between 30 and 65 psi. Designed to fuel anything from 150 to 800 horsepower, these pumps flow over 450 lbs. per hour at 45 psi.
it has a russel efi fuel filter and some an fitting and about 1-2ft of 1?2 braded fuel line.
300 for all of it
i also have a new
chicago tool powered coating tool, i paid 80 for it on ebay , will sell it for 45.00
new 5gal sand blaster holds 20lbs, used one time 30.00
2 used 10" elec fans
new 5000lb tow bar 45.00
felpro 1400 gaskets new 15.00
2.73 gears for a 8.8 ford 10.00
will trade up for some performance parts for a 89 mustang 5 liter
MAF
I would love the stock MAF....50 bucks...consider it sold....What kind of pay do you take?
Thanks,
Matt
