I've had five turbo 86/87 turbo T-Types over the past almost 20 years, and I keep buying one, keeping it for a while, buying parts, then, selling the car and parts. I'm just one of those guys that seems to get bored easily and always working on a new project...then, the turbo bug bites again.
Anyways, just sold my last T, at least for a while, so, time to sell parts off again. I've sold on here a couple of stashes of parts like this, so, many will probably be repeat buyers, but last time, I was up in Michigan. I'd like the parts to go to us Turbo Buick nuts like this versus eBay if I could, but I've got over 300+ all-positive feedbacks there if need be.
Now, I'm back in the Dallas area for those that need to pick something large up. For Paypal, address is the same as my email: ruqwikr@yahoo.com, but only shipping to confirmed Paypal addresses. Otherwise, cash, check, or MO.
Don't bother low-balling as I am NOT desperate.
Prices do NOT include shipping...shipping charges are reasonable...what can go PO, will go that way, larger items FedEx or UPS Ground, only insured, too.
I'll edit the post as stuff officially is sold...
NEW as in NEW not nearly NEW: - all are real GM unless noted & for LC2's unless common others
-GNX 02 sensor $25
-GNX 02 sensor, also new, but out of packaging, $20
-Coil packs, original Delco's (older original versions), $60 each - have 3
-Powermaster accumulator, $200
-A1-Cardone Powermaster accumulator (got from Kirban recently for $180), $160
-Cam sensor with drive assembly, $150
- Cam sprocket for timing chain, $30
- Front cover, $125
- Oil pump pickup tube with screen, $15
- Delco LC2 plug wire set, $20
- Turbo heatshield, $55
- C68 electronic climate control blower control module (goes underhood near blower fan), $175
- Door strap screw covers, $10 each - have 4, maybe 6
- Grey appliques for floor shift console trim plate around shifter, $40 each - have 2
- Grey lace for around Astroroof opening, $40
- Set of 3 GN fender / trunk emblems, $135
- Pair of "Intercooled" emblems, $55
- Pair of "T-Type" fender emblems, $55
- Pair of "3.8 SFI TURBO" hood emblems, $55 - have 2 pairs
- "3.8 SFI TURBO" all-chrome trunk emblems, $70 each - have 2
- "Regal" quarter-panel emblems, $25 each - have 3
- Pair of 'T' fender emblems, $55
- 84-87 style turbo hood ornament, $190
- Pair of black headlight bezels, $150
- 6-way power seat switch assembly, $30
- LF, LR, & RF black wheel well opening moldings - only selling together, $475
- Rear differential housing cover, $20
- Pair of main wiring harness clips for up near HVAC module, $30
- MAF sensor-to-turbo flex hose, $40
- Grey floor shift handle & retaining clip, $25
- Two sets of four Kirban / GNX-style wheel center caps, $40 per set
- Moog stock replacement rear coil springs, $25
Nice USED parts
- 87 shortblock (cam, pistons, rods, stock-sized crank, oil return line, main caps)...~60K miles, all pistons can move freely...stored in HVAC-controlled garage...may be able to be cleaned up as-is without rebuilding, but not positive...$800...not shipping, but will help with deliver within a 2-4 hours of Dallas...I'll throw in a grab bag of mixed parts, too, like a spare oil pan, etc.
- Complete sunroof module assembly (main pan, motor, glass, switch, headliner cover - fabric off)...worked when pulled out...same as the shortblock about not shipping...$250
- Aluminum radiator core support...$250...will ship, but shipping nears $80 from the last one I sold due to size
- Pair of natural rubber tubes for slicks, $20
- Torque strap, $10
- Pair of black headlight bezels...good shape, but not show quality, $35
- Two 84-87 turbo hood ornaments...one is very nice ($100), one is nice but has a scratch on the chrome base ($60)
- C68 electronic climate control set up...main unit, vent control box from behind the dash, inside & outside temp sensors...was working when removed...great for spare to have around, $180
- Turbo instrument cluster for floor shift car includes black rear surround that it goes into as well as a nice front trim plate, the one that includes the little emblem (3.8 Litre)...that has the left A/C vent, park/turn light switch, and rear defogger switch, $150
- Purple / burgundy carpet from ACC...color matches perfect...in the car for a VERY limited time...saves weight, too, $100
- Almost new set of front air dams that bolt to the underside of the bumper...I bolted them up for some pictures only, $60
- Intercooler brackets (traingle one, and 90-degree one), $40
- Stock upper plenum opened to 62mm, $40
- Almost new fuel rail plus almost new Accufab adjustable fuel pressure regulator, $200
- Almost new stainless test pipe with 3" dump for a 3" THDP system, $50
- Two fuel pump hangers, $25 each
- Excellent shaped stock 200R4 oil pan with magnet, $35
- Nice Powermaster motor, $50
I may find some more stuff to list...happy shopping.
ONE LAST THING...I try to be very good about answering emails, but over the next couple of weeks, I have a lot of family and work events, so, be patient. Thanks.
-GNX 02 sensor $25
- Front cover, $125
Nice USED parts
- Torque strap, $10
