T
TurboShortBus
Guest
Looking for exhaust housing inlet and outlet flanges only, for project...>>>
Does anyone know where I can buy just the exhaust inlet and outlet flanges for a stock 1986-87 GN turbo? I need a pair of the 3-bolt turbine inlet flanges, and a pair of the 4-bolt turbine outlet flanges (yes, I'm building a twin turbo setup). The 4-bolt turbine outlet flange only needs to have a single 2.5" hole in it for the downpipe (and must block off the stock wastegate hole), since I will be using remotely mounted Deltagates.
The 3-bolt GN turbine inlet flanges appear to be identical to the turbine outlet flanges for a Syclone/Typhoon turbo, so I suppose they would also work.
Thanks,
Mark
TurboShortBus@aol.com
Thanks,
Mark
