87 grand national 62k mile scan master, 60's injector, tt chip, tin man cold air, rjc plate, adj fuel reg, cottons coil, 10.4 Taylor wires, ls1 maf and translator, 160 thermostat and housing,rjc 3"down pipe, rjc 3" exhaust, Rjc 315 ic, rjc 3" maf pipe, rjc boost controller, 6262 percision turbo, adjust roller cam button, 1.65 t&d roller rockers comp cam roller kit with double roller timing chain kit from cottons 255 fuel pump hot wire kit fuel gauge boost gauge double nozzle razor alky kit ported heads and intake cometic head gasket arp studs cottons valve cover kirbans vacuum lines, alradco aluminum radiator with cooler lines, spal dual fan kit will need to change my chip to support alky not sure which way to go with torque converter and building my trans and which drive shaft to use also looking to install new shocks and coilovers what do you guys think of this set up so far
