iam looking for a 9sec gn or t-type for trade for an 8 sec street mustang here is some info
car
88 lx 4cyl car 44k miles before touched this car was being built for eif renagade class in the nmra it is now carb setup never been down the track all new
a4 block 310in motor
billitt main caps
la billit crank
grp 2000 alum rods best on the market
je nos pistons 13 to1 with 4 extra
tool steel pins
dannny bee belt drive
fluid dampr
internally balanced
csi flywheel
canton pro oil pan
windage tray
victor jr fully ported heads by foxlake
jessel rockers
moroso fab valve cover
super victor intake drilled and tapped for fogger system
barry grant reaction time carb flows over 1080 cfm
nos super big shot plate
mitty mite c4 with brake and 9in 4400 stall nos conv
alum drive shift
8.8 rear 33 spline moser and spool and rear cover
full wolfe suspension adj upper and lowers and anti roll bar
QA1 rear adj shocks
QA1 coil overs fully adj
upr crome moly k-member and a-arms
flaming river rack
alum rad
12pt cage
stock interior
alum 15gal cell #12 line to feed bg400 pump and #10 line to the front
there is alot iam missing but everything is new there is about 100 miles on everything and alot more i forgot
also giving all efi parts that i have for the car harness never been cut it takes 5mins to put back in computer victor 5.0 intake fully ported by foxlake to match heads with nx pro efi fogger on it that was installed by nx with the big iceman solenoids 40lbs injectors vortech fuel rails 75mm tb pro-m 80mm maf 4" alum intake with k&n filter its about $4000 in parts alone have pics and car is reged and insured i have collector insure though north east collector insurance i have 40k in this car email or call 516-807-0847
car
billitt main caps
la billit crank
tool steel pins
fluid dampr
internally balanced
csi flywheel
canton pro oil pan
windage tray
jessel rockers
alum drive shift
QA1 rear adj shocks
flaming river rack
alum rad
12pt cage
stock interior
