Logging Fuel Pressure with XFI Help
huntsg
I'm sure it's here somewhere, but I searched and can't find it. I'm hooking up a fuel pressure sensor (got it from Julio 2 years ago and used it with my power logger until I switched to XFI) to my XFI. Can someone tell me where the signal wire goes and how the calibration needs to be done? Thanks.
Depends on your adapter ?
How old is the box ?
Caspers changed the box about three years ago so that now most of the wiring is done and you plug into the EGR plug.
One of two way to tell is to open the box (four small screws) and see if it looks like mine of if it has white boxes and you have to manually change the jumper.
Thanks. I don't have the Caspers box. I think I need to wire directly to C 12.
Sent from my iPhone using Tapatalk Pro
Then you have to use one of the eight auxiliary inputs on the "B" plug.
Goto the 23.0 section of the help section
I think it's the C plug. When I look at the pin out table in the help section it shows the B plug for auxiliary outputs and the C plug for inputs. Does anyone know where to order the pins that plug into the connector? From FAST?
