Like new, Pro Star style wheels
1owner
Used for 300 miles. Damaged at tire store. Three (3) have slight damage on outer lip. The one (1) in the pic is the worst.
Two (2) 15 x 7, 5 x 4.75, 0mm offset, 4" backspace.
Two (2) 15 x 8, 5 x 4.75, 0mm offset, 4 1/2" backspace.
Four (4) Flush valve stems .... w/ inflation tool.
New $475 at Summit Racing.
istvan31@live.com [atlanta area]
if you leave that plastic ring that comes with new wheels on the rims when they mount tires- it will avoid all the damage these tire mounters seem to cause.
Or they could just use the think plastic piece that's supplied with the tire machine (it goes over the arm so as not to scuff the wheel). You gotta watch those maniacs :eek:
I wanted to powder coat them and leave just that lip shiny.
What grit would you suggest? :confused:
