Had this all typed up last nite and the computer locked up. Anyways little less than 3 hour install. 10,000 lb Rotary symetrical 2 post,extended height lift. I had go the EH route because my ceiling is 11'4 and most need 12 ft. Other options were in ground(expensive) and base plate(dangerous for trans jack). Up stairs will be a train room someday so I can build over the parts that is up there.
I am going to relocate the saftey bar to the header that runs in the center of the garage.
The buicks go to full rise,I had a Tahoe on it and it was a little lower but I could still R&R a trans if I had to. I don't plan on putting anything bigger than a full size truck SUV.
I am tickled pink to say the least. I still need a better compressor and have to run air line around the entire shop,but my portable will do for now. Also maybe a bead blaster,and some other misc equipment as $$ allows.
Here are the pics..:biggrin:
