I have about 58,000 miles on my TTA. As far as I know, it has the stock injectors. The car has always ran rich at WOT (high 800's-mid 900 mv). Keep in mind I am using Diacom as a scan tool, so the O2 Voltage is shifted about 50 mV higher than the other scan tools. Anyway, I was playing around with it this weekend, trying to do a little tuning. When I got home, I pulled the spark plugs and the #6 plug was black with a lot of raw gas on it. The other plugs looked white...as if the engine was running lean. Because of the one rich cylinder, I had suspected that the fuel injector may be bad. Plus, I have had problems with fuel pressure dropping to zero within an hour after the engine was shut off, and I have also had a hard start issue for awhile.
So, I pulled the injectors out of the intake manifold and cycled the key on to prime the fuel system. I then watched the fuel injectors. 2 of them started to drip ever so slowly...while the injector on the #6 cylinder showed no signs of leaking. Visually, they all have some varnish and buildup on them. I am planning on sending them off to be cleaned and flow matched. But before I do, I wanted to see if anyone has had similar problems (one cylinder running really rich)? I had this same problem on my old 87 IROC-Z and it turned out to be a bad MAF. Don't ask me why...but it caused the #8 cylinder to run rich...of course this was a batch fire system also...so the inefficient air metering may have been affecting the fuel distribution? Any advice or insight is appreciated...thanks!
