Well my powermaster is acting up and seems like i'am not the only one. I went through the trouble tree and didn't get much. Whats happing is you will go to stop and have a hard pedal and than it will catch and throw you through the window. My brake light is not working when you key up or when you press the parking brake. I pulled the pressure switch connector and found it soaked with brake fluid. It seems to be leaking out the top of the switch. Is this a common problem? The motor does not cycle when you pump down the system but I know the motor works because I jumped it out through the pressure switch connector. I just wanted to ask some questions before I start throwing money at this thing.
Thanks, Dave
Thanks, Dave
