Large amount of parts for sale
GN FAN
this will be the last of my stash of new and used parts.........I have pics of everything if you don't see them posted just ask and ill send them out prices are listed without shipping.
My pay-pal is ettorc@hotmail.com, first with the money is the winner.
Weld Draglite wheels Front 15x5 3.5BS/Rear 15x8 4.5BS
Mickey Thompson ET Drag 26x10x15 Sportsman Front 26x7.5x15 8 ply
4 Centercaps and 3 sets of McGuard Lug nuts (1 front 2 rear)
Used only for racing once per year tires have plenty of life left
asking 800.00 firm....also on ebay
Wells blower motor resistor new.................................10.00
GM coil pack and gasket new......................................150.00
1 set spark plugs CR42TS new.....................................12.00
1 set spark plugs CR43ts new.......................................12.00
GM fuel pump relay new..............................................20.00
GM pvc valve new.........................................................5.00
(2) GM fuel filters GF652 new.....................................10.00 each
Denso heated o2 sensor new........................................50.00
Cam sensor tool new.....................................................30.00 SOLD
Fel-pro rear end gasket new.........................................10.00
(2) turbo to exhaust manifold gaskets new..................10.00 for both
1986 GM service manuals in binders used...................100.00 SOLD
Oil filter remote mount with feed line used..................50.00
Refurbished 200-4r BRF valve body............................150.00
Vacuum brake conversion kit........................................100.00
Ceramic Coated crossover pipe and coated plenum to intercooler pipe...................150.00
passenger side exhaust manifold used..............................50.00
Refurbished driver and passenger exhaust manifolds.....100.00 SOLD
GM lugnuts 10 T-type 9 GN various conditions...............10.00
GM passenger side headlight bezel and corner light - black......................................100.00
Gbody fiberglass front bumper fillers new.........................50.00 SOLD
T-top weather strips new...................................................50.00
Front end bracing kit - 2 bars and hardware new.............50.00 SOLD
86-87 PCM used.................................................................50.00
Pair of front bumper turn signal lights used.....................50.00
passenger side pcm housing and kick panel gray used.....25.00
96 LT1 b-body MAF used...................................................50.00 SOLD
Microtech Turbo Buick MAF used.....................................50.00
TV cable used.....................................................................20.00 SOLD
GM spark plug wire set used.............................................10.00
Wastegate actuator y-lines new.........................................40.00 SOLD
GM turbo oil drain tube and gasket used..........................50.00
Jack assembly out of a Regal Limited used.......................25.00
pics
more pics
last bunch
Do you still have the Brake Conversion Kit? Does the kit include master cylinder,vacuum assist canister ,brake pedal and bracket, check valve, and large vacuum hose? If so I'll take it...
