Lance, Craig, or anyone,
File this as a future feature request, but it would be great if there was some way to adjust the sensitivity of the knock sensor. Maybe this isn't possible with the GM ESC module; I don't really know, but on my noisy SOHC four banger, I find that I'm getting too many false positive hits to be able to use the knock sensor -- it's noisy enough that it retards timing at idle.
As a result, I will probably be adding a J&S SafeGuard knock sensor, which is a nice enough piece that i don't mind adding it, but I lose the ability to log knock sensor activity.
Does anyone have any thoughts on this? I know for most of you this isn't an issue, as you're using GM parts on a GM engine, but for those of us using these same parts on non-GM applications, things are tougher. Or maybe someone knows of a GM four cylinder knock sensor/ESC module combo that would work with the SP???
Jeff
Jeff
