91rangerturbo
Turbod
- Apr 6, 2006
I installed a caspers knock guage my 84 GN. I ran three wires one the yellow/black striped wire coming from the ECM. Then i ran two other wires a hot wire to the radio fuse. Then a ground under the dash.
My problem is that my Knock gauge displays the green light dim while you have the car running.
But if you turn the key backwards to accesory then it will get brighter. The way it looks like it should work.
Is there somewhere else i can tap it in too.
or am i missing something.
