pontiac6269
- Oct 26, 2006
This last weekend I installed new injectors and then installed new valve springs. When I turned the key on to check for fuel leaks I discovered 3 injectors leaking at the fuel rail #'s 1,2 and 4. As I was checking this I looked at the cowl to were the spark plugs where sitting and thought O great I'm missing a plug. Looked at the radiator support were all my tools where and figured it was buried under them. Anyway today I changed all the injector o-rings, checked for leaks and had none this time. Buttoned things up to where all I had to do is crank engine to get oil pressure, then install plugs and fire up. Thats when I realized that Saturday when I thought I was missing a plug I was thinking it was a V8:biggrin:. Must be from working on my Pontiacs. As I have tendency to do a little work on each car at the same time.
