TurboBuickSix
- May 23, 2001
Thought I would suggest a cheap or even free but very effective way to keep your ride from being taken.Get a cheap 12v siren from somewhere,garage sale,flea market, ebay, maybe you have part of an old burglar alarm you took out of a junker long ago like me.
get a switch,(I use mini style) that is :
on-----siren-no ignition
off-----no ignition,no siren.
on-----ignition
Tapped into the starter wire under the dash and hidden where you want it.Thief breaks column,thinks to himself ok then pushes the bar, and instead of starting gets the crap scarred out of himself while hopefully drawing attention.This should help move him along his scumbag way faster than he might with just a kill switch alone.This could also be augmented by another device that keeps the alarm sounding after it has been tripped.Another option would be to install a second siren or air horn(use your imagination)INSIDE the vehicle so he can hear it much better.Be sure to hide the wires under the hood going to the siren inside of existing wire looms and try your best to make it look like factory wiring,be creative you have to want to keep it more than they want to steal it.There was also someone that mentioned the availability of remote control switches that "sport compact enthusiasts" were using that would work great for this.I posted this because so many thefts have been happening lately and the season for it is here.Be careful and good luck.
on-----ignition
