gage mason
- Jan 20, 2013
On start up I have a weak idle..it's up and down from 600-800ish. These numbers are after a 5 min warm up.
Af-04
L8-30
Bat-12
Int 150
Bl 150
Clt 187
Ats 57
R 750
Tps .52 idle 4.54 wot
Iac 39
Cc up to 252 then restarts
Mal 00
On recall mode I had 726 o2 and 3.00 knock
Then it read 081 and 067 on the second screen
I know I have tps adjustment to do and my int is to high. Should be 128 right? It read that after a run but not idling. What else can you guys tell from this and what should the off numbers be reading as a properly running GN?
Af-04
L8-30
Bat-12
Int 150
Bl 150
Clt 187
Ats 57
R 750
Iac 39
Mal 00
