jeep steering shaft upgrade,grand prix bar
LSJM1
Grand prix bar or brace that runs in back of the rad support between the frame $30 shipped
jeep steering shaft upgrade,replace that sloppy rag joint shaft with one of these,it has u-joints and gives a much tighter feel.Shaft is cleaned,painted,slip fit coupling is freed up and lubed {hard to do} ready to be used $40 shipped thanks
The shafts come from 84 to 96 cherokee some grand cherokee ones will work but others the shaft is too small on the top side.Also do not take a hammer to it to free up the slip joint,just heat it up with a propane torch at the joint untill the plastic bubbles out and the shafts will slide apart.If you hammer it you will mess up the u-joints.I have 4 of these I will part with and the u-joints are perfect
Been looking for this steering shaft for a while now. I want to be next in line. PayPal is ready to be sent!
heres a pic of the shaft ends
I'll take it!!
Let me know here or via PM if it's still available. I can send PayPal.
Sincerely,
John A, Turbohh
