You MAF dropped out at frame 549 and right then you got 3 degrees of KR and it drops here and there again. The O2s don't look too lean but the BLMs say different.
Good catch on the MAF. So what do you think that means? Is the MAF going away? What do you think about the BLM's? I got 10% added fuel in the chip, so it really shouldn't be low. If anything maybe a little rich. I think Eric told me to target around 11.5 A/F.
You can typically run the A/F in the mid-high 11's when the boost is low like that on a stock type setup, as long as it doesn't knock. If it's knocking then richen it up to see if it helps. If it doesn't help then either reduce boost, or reduce timing 1-2 degrees.
Your MAF is ok. You are just seeing the actual MAF reading in the backround before the chip forces it to 255. It's not affecting the injector pulsewidth.
You could also dump in some extra octane to see if the knock goes away.
Eric- Thank you very much for your help. I was going to put this log on your board as well to ask for your help. I wanted your take on the MAF.
Thanks for the feedback.
I still had knock even with the A/F in the high 10's. I was thinking it was false because I put in the 20% fuel and can't ge the knock to go away. I can't get my boost lower than what I have it at now. I guess I can try some race gas and see if that helps out.
Is this common to see knock with 16 psi and an A/F in the high 10's. I have had this problem ever since I bought the car and then installed the powerlogger. The person before me had no scan tool. They were running even more boost than I am when I first bought the car.
