alwayscode390
- Apr 2, 2009
I bought this from a board member a few years ago and never even opened the box until tonight.
Is this setup complete?
Its a peice to the turbo with the wastegate puck inside ( does this mean its an INTERNAL wastegate?) and 4 bolts.
Then two more peices that make up the downpipe. All three peices slip together.
I saw a thread where they had a "test pipe" too ... I am confused at how I am supposed to connect this setup of mine to the exhaust. Do I need a test pipe with the flange that hooks up to the cat with a flange? Who sells the test pipes and the flange I need to put on my 3" universal cat ... or will most exhaust shops just use their own flanges for the end of the D.P. to the end of the Cat? My car is catless right now, and wont pass inspection without one, so I will be using the Magnaflow Universal 3" in / 3" out.
The first pic is my setup ... then the second is a picture I found on the forum with the test pipe peice I am missing.
Thanks for your help ---
