Interesting info on e85.
wilkinshc
Some Throttle More Bottle
This was posted on www.E85fuel.com:
E85 Saab
With all the buzz about hybrids, it’s easy to ignore our homegrown alternative fuel: ethanol. Clean-burning and infinitely renewable—we’re talking grain alcohol—ethanol is dear to environmentalists and economists alike. The standard E85 is widely used in Sweden. The fuel has about 75 percent of the potential energy of gasoline, so it takes up to 20 percent more hooch to keep horsepower on par. But E85 also has a high octane rating (around 110), and Saab realized that a turbocharger could harness it. Turbos push extra air into the cylinder, and higher octane allows a fuel to better endure the increased pressure. So Saab cranked up its fans and created the BioPower engine, the first commercially available ethanol turbo. A computer samples the fuel mixture and adjusts boost pressure—from 5.8 psi for pure gasoline to 13.8 psi for E85. Running straight gasoline, the engine produces 148 horsepower, but E85 jacks it up to 184, with no penalty in fuel economy.
Now if you were to put in a comparable pump and replace the fuel lines (not we even need to). Seem like you should be able to run more boost (assuming that is what the saab is doing) on cheaper e85, especially at today's price.
Just thinking out loud.
I have been thinking about this stuff for a while now,I was going to give it a try but it is not available in my area yet.
