I'd have NO luck at all.
I ran to Autozone this afternoon to grab a few gallons of antifreeze for the hotrods. It's been starting to finally get cold around here, so I figured it was time to dump the water.
A couple weeks ago I pulled the lower rad hose off the Camaro sitting in the trailer outside and drained the water... leaving just what was left in the block temporarily.
The GN stays in the (semi-heated) garage.
I came back from Autozone with 3 gallons of Prestone.
I crawled into the trailer to put the lower hose back on the Camaro... and started dumping antifreeze back in. I got two gallons in and wondered where it was all going...
Apparently it was running out of the freeze plug that was pushed out of the drivers side of the block.
I looked at the passenger side, and sure as $hit, that one is about to fall out too...
Both freeze plugs are in impossible locations, so now the goddamn motor has to come out. I just hope to God it didn't crack the (Hi-dollar Chevy Bowtie) block.
I just can't catch a break. I feel like such a fvcking douchebag sometimes.
