my sons 85 t-type, has had cam sensor,crank sensor, 87 coil upgrade, new jasper motor, his stepdad went to pick it up from the shop, they pulled it around and i sat an idled for five minutes and he went to drive off and pull it into gear and it just died. it would idle, but wouldn't run when put into drive.
he is going to replace the iac motor/sensor and i was wondering if there was anything special to do when you do this or is it basically the same as when you reset one?
