Hello everyone,
I have done about every bolt on performance aid to my '87 GN and it STILL will not do better than a 12.50 ET
A few people told me to check my fuel pump. A friend let me use his extended hose fuel psi gauge to view outside of the hood while driving.
Anyways, I've been told by everyone that it should read 1-to-1 psi to at boost. With vacuum line off of fuel regulator it reads 43 psi. At WOT with 28-psi (yes you read that correctly 28-psi) it, the fuel psi gauge, reads 63 psi. So to my understanding it should be around 71psi. With this test results, should I get a new fuel pump now? If so, will this improve my performance that much?
I attempted to attach a couple PL file's from last night runs. Hopefully I did it correctly.
Any help would be greatly appreciated, thanks all in advance!
