PhilthMonger
- May 1, 2003
for the past 3 months I've been re-constructing everything on the GN....had a blown turbo, cracked headers, and oil leaks from every orifice imaginable. So, I basically pulled the motor and resealed everything. while I was there I threw in a converter from Pat's Performance, a nice PTE turbo, blah blah blah everything is basically new. the moment of truth comes, to fire the beast back to life....no start. major backfiring in the intake....I really hope I didn't blow the intake manny gasket doing this by the way. anyway, I re-installed my cam sensor. brought it up to tdc to what I thought was the compression stroke, which in my demented mind means valves closed/ piston coming up and blowing air out the plug hole....please correct me if I'm wrong. I went 25 deg after tdc and stuck the sensor in with the harness facing the driver's side. (gear dowel to the back) I got kirban's cam sensor tool, and set it according to the led. same backfiring, wont start. for kicks, I did it again on only on the opposite exhaust stroke, same thing. the throttle body elbow gets real hot due to all this backfiring. I'm definintely getting spark and fuel.....just in the wrong direction. I'm kinda leaning toward crank sensor on this one, it was caked in oily sludge and dirt when I removed it....I just cleaned and reinstalled. Would a bad crank sensor cause such violent backfiring in the intake? Am I way off on this? I have alot of experience in turbo imports, this is the first GN I have ever touched. I have to say, the archives on this board were very helpful to this point. another thing worth mentioning, I had a new PTE chip burned for my new injectors. I have tried starting the car with this chip as well as the old stock chip and everything is acting the same. This car did in fact run before I tore it up! any ideas or suggestions would be greatly appreciated!
