Hey Guys,
I have some questions about the 87 T suspension. I'm in the process of gathering parts to rebuild the suspension, front and rear. The car has 180,000 miles on it. I have new stock ACDelco front and rear coils and shocks. I have ordered a front end rebuild kit with stock replacement parts. I need to find out about the front and rear spring isolators. Do you have to have both upper and lower isolators? What are the part numbers for the sway bar end links and sway bar bushings, (front and rear, stock replacement)? The part numbers for the upper and lower rear control arm bushings, (stock replacement)? Do you need to replace the front lower A-arm rubber bumpers? Do you need to replace the hardware that retains the upper and lower rear control arms? And do you need to replace the rear pinion snubber? I am new at this and trying not to sound like an idiot and I apologize for the amount of questions. Any help that any of you can provide would be greatly appreciated. Thanks Again.
Sincerely,
67gsconv
Sincerely,
67gsconv
