Been workin on this car for weeks. One thing after another since I bought it but finally she is running good.
New Plugs
New 8mm Wires
New Intake Gaskets
New Oil Pan Gasket
New FPR
Injectors Rebuilt and Matched
New TB Gasket
New Upper Intake Gasket
New TCC Solenoid
New Tranny Oil and Filter
New Rear Diff Oil and Additive
New Silicone Couplers with T Bolt Clamps
New Air Inlet Tube
New Air Filter
New IAC
New EGR
New Heater Core
New PCV
New PCV Grommet
New Fuel Pump and Starainer
Hot Wire Fuel Pump
Cleaned Out Intercooler
New Valve Cover Gaskets
New Vaccum block Gaskets
Rebuilt Stock Turbo
New O2 Sensor
New MAF Sensor
New AIT Sensor
New Fuel Filter
Repaired Grill with New Springs
New Tires
Installed Clean Set Of Wheels with Good Caps
New KYB Shocks
New Filler Neck Seal
New Vacuum Hoses
New DownPipe Donut
Reset TPS and IAC
Clean TB
Removed Bad Aftermarket Alarm
New Battery
New Battery Hold down
Fresh Oil Change and Filter
Took her out for a ride yesterday and look what happened.....uh ohhhhh
Thinkin about sellin it now....lol...new project time
New Plugs
New 8mm Wires
New Intake Gaskets
New Oil Pan Gasket
New FPR
New TB Gasket
New TCC Solenoid
New Air Inlet Tube
New Air Filter
New IAC
New EGR
New Heater Core
New PCV
New PCV Grommet
Hot Wire Fuel Pump
Rebuilt Stock Turbo
New O2 Sensor
New MAF Sensor
New AIT Sensor
New Fuel Filter
New Tires
New KYB Shocks
New Vacuum Hoses
New DownPipe Donut
Reset TPS and IAC
Clean TB
New Battery
