Ok thanks. I don't think it's 7 steamboats. It was the same with the factory reservoir. So I guess that third port isn't any more effective than the "T" with 2 ports. Oh well, at least it looks badass.GNRick,
Funny you mention this, as I was just discussing this with another Buick buddy who's also done the HydroBoost conversion.
He said that this is normal with the HydroBoost. I have found similar with my Tallon Hydraulics HydroBoost / PSC reservoir combination too!
I find that after releasing the brake pedal from fully depressed (to the floor) position, I can count 1-2-3 steamboats and it fully returns.
We compared notes and found the same timing on both our cars.
Think that if it takes longer to return , like 7 steam boats , it's too much and some other issue must be prevalent.
My vacuum brake set up was a little quicker to return and not as noticeable.
So, I guess it's just something you'll experience and have to get used to with the HydroBoost Brake set up.
Plenty of fluid. MC was bench bled. I have fluid to the caliper, just not through it. Weird.Maybe you are just low on fluid?
I have this vac pump system that I use to do oil removal and changes from my daily driver that has its oil filter on the top of the motor. Works really well but it's big. I'll try it.May sound silly, but remove the bleeder nipple and ensure that there is no debris or obstructions.
I removed my factory proportioning valve on the frame and installed an adjustable wilwood which hangs beside the master cylinder. Was able to bleed the rear brakes no problem, but I had a difficult time bleeding my front brakes. Installed new front L&R brake lines to the callipers when I installed my 2WD blazer spindle / dual caliber change over at the same time as my HydroBoost installation.
My Motive Power Bleeder wouldn't even succeed in getting fluid thru the front brake lines. I did have some luck (finally) using my Mity-Vac vacuum pump in being a able to suck some fluid thru.
Then had a buddy help me bleed the brakes (the old fashioned way) by pumping the brake pedal in unison with opening / closing the bleed nipple on the caliber in order bleeding the air out and get the fluid moving.
My suggestion is to try a Mighty-Vac pump and pull the fluid thru.
Also, my brake light came on and stays on. What triggers that?
Sent from my SAMSUNG-SM-G900A using Tapatalk
The slow return pedal is normal. Over time, 2-300 miles of driving it will either improve, or you’ll forget about it. I lost count on how many conversions I’ve done but it is typical.Ok thanks. I don't think it's 7 steamboats. It was the same with the factory reservoir. So I guess that third port isn't any more effective than the "T" with 2 ports. Oh well, at least it looks badass.
I probably have 3000 miles on it.The slow return pedal is normal. Over time, 2-300 miles of driving it will either improve, or you’ll forget about it. I lost count on how many conversions I’ve done but it is typical.
I would imagine I have over 2 on mine, I think I stopped paying attentionI probably have 3000 miles on it.
