Boostm3 @ what point do you start to experience knock? You want the turn on point to be about 2psi below that. I would think the same would apply to a supercharged application
Bob, Im in a little different position than most of you guys. You can change your afr and your timing at will. But with an OBDII M3, the software that we get with the Dinan base supercharger kit is pretty much the software were stuck with. Its a minor miracle in its own right that this software is written so that it ran the car well when I was 8 psi out of the box, and now at 11 psi. In addition, there's a 5V HFM signal limit, beyond which it starts throwing lights and codes. I hit that at 6000 rpms. Redline is at 7000 rpms. Just shy of that 5v 'limit' Dinan has implemented an 'hfm clamp' which freezes the signal just shy of 5V. What this means is that while Im way rich at 10:1 at 5800 rpms, by the time I get to the 7K redline, Ive leaned out to 12.7:1, which is still ok, but I realize that anything which would add more airflow will cause be to be unacceptably lean. There are only a couple of tuners in the country that can tune this software, so Im going to take the fact that with a 10.5:1 static CR and no intercooler, being able to product 11 psi with no knock, and 350 rwhp as a blessing, and not push my luck.
In answer to your question, I dont hear any knock without the water injection. But I do see egts rise higher than Id want, and the intake air temp sensor as well, and I can feel the timing being pulled up high, but I cant tell whether thats in response to unheard knock, or to the high IAT values which will also cause timing retard in our cars. AS for turn on point, dont forget the shape of the curve delivered by a centrifugal blower, vs a roots style or a turbo. The latter two deliver a torque curve in the shape of a big hill right off the bat, and it declines the rest of the way. whereas on mine, it inclines to about 4K, and it stays at that level almost to redline. Its a very flat torque curve, but the biggest difference is the shape of the boost curve. Roots blowers and turbos make alot of boost way down low. But on a CF blower, we use roughly the forumla that as the rpms are doubled, the psi values are cubed. For instance, at half redline, 3500 rpms, I could be making just 2.25 lbs of boost. But at 7000 rpms, Im making 2.5 x 2.5 x 2.5 or 11 psi! So, its steadily increasing but ramps up quickly near the end. This means that I have to trigger a little differently than you turbo guys because the volume and turbulence of the air isnt there until higher up. If I were turboed, Id probably trigger around 3.5 psi. But Im finding that 4.5 to 5 psi is just about perfect for the .7mm jet.
