H HOTSIX Ran outta hand cleaner Joined May 27, 2001 Mar 26, 2011 #1 How do you test for a bad Colland Temp Sensor? My electric fans stopped kicking on and I cant figure out whats bad. If I use a voltmeter on the blk and yel wires can I check it somehow to see if its bad?
D DailyDrifter The Slow and the Curious Joined Dec 5, 2007 Mar 27, 2011 #2 Jump the fan temp switch to ground on the harness side (the one with an "umbrella" type connector)..... if it turns on then the fan temp switch is bad. The coolant temp and fan are 2 different sensors.
