R
ri87T
Guest
How much does it cost to get the ecm modified to handle bigger injectors?
Originally posted by zam70
I believe intercooler had a post a few weeks ago explaining that a mod was actually not needed . Just a larger fuse on the circuit...you might do a search, it had some good tech links with it as well.
, care to comment? [/B]
Originally posted by bruce
I've got 2 years and lots of long trips on my Bailey modifed ecm, using 55s I have a smoother idle then ever, and have broken 30 MPG. And with a 60 turbo, and running 23 PSI on pump gas, I'll leave the performance to your imagination....
Originally posted by GNVAIR
Bruce, please explain what was involved in being able to run 23lbs of boost on pump gas. When I think of pump gas, I think of 93 or 94 octane fuels that are readily available.
Using the P+Hs generates less heat for the injector drivers to deal with.
There's alot of myths still hanging around....
Originally posted by Ruce
Carl James, also runs his ecm with the oem injectors, and I have tons of repsect for him, BUT he also has enough talent to get the calibration right after making said non-changes.
I'll take a pass at it - hope you don't mind.Originally posted by TurboBob
you guys will have to double check my math.
Stock ECM, stock injectors
12volts, 12 ohm, Darlington transistors(1.2Vce)
ECM 1.08 watts per 'channel' .9 amp per channel,
7.2 watts total in the ECM, 12 amps flowing in the ground pin at 100% dutycycle
Injectors dissipate 10.8 watts each at 100% DC
P&H 2.5 amp
12 volts 3 ohm (impedance goes up with temp.)
ECM .5a hold current drops 1.5 volts in the injector leaving 10.5 in the ECM
10.5 volts at .5 amp per channel in the ECM is 5.5 watts per channel in the ECM
33 watts total in the ECM
.5 amp per channel 3 amps total flowing in the ground pin
Injectors dissipate .75 watts each at 100% dutycycle
Using the 1.2 Vce as above, 12-1.2=10.8V across injector, /3 ohms = 3.6 A per channel, * 1.2 V = 4.32 W per channel in ecm, * 6 gives 21.6 amps and 25.9 W total in ecm. The saturated drivers dissipate less power in the ecm than the peak and holds. However, 10.8 V * 3.6 A = 38.9 W dissipated in each injector - don't run them dry. Actually, in my case Vcesat is more like 0.6 V so the total power dissipated in the ecm is 13.7 W.Low impedance injectors with stock ECM
12 volts, 3 ohm
ECM 5.25 watts per channel 3.5 amps per channel
31.5 watts total in the ECM
21 amps flowing in the ground pin.
Injectors dissipate 36.75 watts each
I've heard of one person getting away with using the stock drivers with low impedance injectors, but I've heard of several people who let out various quantities of magic smoke trying this. I didn't even consider it for myself. As for the total current, I've done this math several times, and I know the fp/inj fuse is 15 or 20 A, not 30 A, but I've never heard of anyone blowing this fuse using saturated drivers and low impedance injectors. Oh, of coure all these power estimates are a little low if the alternator is up to snuff, since we should have used 13.5-14 V instead of 12 for the supply voltage.This assumes the stock ECM driver transistors are up to the task.
It might work but you are punishing the injectors. The car will run a
lot richer at idle too.
