muddin'metal
- Feb 4, 2008
Car seems to have lost power in the 10lbs+ area and before I start tearing into it, do these seem normal?
All reading taken after long drive at idle in park, OPEN LOOP operation, have translator pro and Lm1
Weather and car info: Outside Temp-75, Water temp-167, Intake temp-116, Oil Pressure-23lbs, Fuel pressure-34lbs, Vacuum-14lbs, Rpms-940, A/F ratio 12.2-6
All scanmaster reading are observed for 10 secs. each and ranges are as follows:
O2 820-824
AF 02-03
L8 33-35
BAT 13-13.3 Its always red in that range
INT 128
BL 128
MPH 0 of course
CLE 165-167
ATS 71
r 875-900
TPS .42
IAC 21-22
CC 13
PL 21
SP 25
No trouble codes... Car does sometimes have a random bog at idle that drops rpms and clears up, and car cruises like turd at any steady tps reading between .50 and .80ish.
What do you think?
O2 820-824
AF 02-03
L8 33-35
INT 128
BL 128
MPH 0 of course
CLE 165-167
ATS 71
r 875-900
TPS .42
IAC 21-22
CC 13
PL 21
SP 25
What do you think?
