Water - screw into one wire sensor location on front of block. Right?
Best location to wire into? Acc Fuse
Oil - came with a sending unit, could I keep my stock sending unit and t out of it for the oil feed line to the turbo and take the other end of the t to the gauge? Wiring? ACC fuse
Knock Gauge - Wire into correct computer location, ground to good source, put into the Acc fuse or radio fuse to eliminate the need of a switch. Correct?
Any help is appreciated how many gauge lights can be powered by wring into the ACC fuse location? If only one what are alternative fuses and locations?
Long post, Thanks for the Help
Kyle Cook
Kyle Cook
