Firechicken
- Jul 23, 2003
Hey guys, because a custom built tranny pan is just waaay too expensive, I decided to make my own. The trans pan itself is made from two stock pans. The bottom is cut off one, and the top is cut off the other. Then they are welded together to make one pan which is about twice as deep as the stock pan.
The sump is made up of simple household copper water piping soldered to a 1/4" copper plate to which a th200 trans filter is attached. (Fram part# FT1036)
The sump pics are below, and I will post the pan pics tomorrow.
Hmmm, I guess I used a bit too much solder. Oh well...it won't leak now.
