I'm freshening up a 60K mile stock long block for my T. I will run stock pistons and basically just rering it (either Speedpro plasma or Total Seal) and put in fresh bearings. This should be a mid 11 sec car.
Now for the question on the heads. I would like to do something to the heads. Since I'm on a budget, I'm not looking for an all out port job. Should I have a fresh valve job done on these heads and then do a little home porting in the bowl and low-flow areas around the valves or would it be better to have the larger Manley valves installed and not worry about porting anything? Any suggestions and ideas would be much appreciated.
